Steering correction kits?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cheyenne_77, Nov 18, 2002.
  1. cheyenne_77
    cheyenne_77 Registered Member
    Aug 5, 2002
    38
    Melbourne, Australia
    Are steering correction kits a necessity with a 4 inch lift /forums/images/graemlins/confused.gif?
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Yes they are needed. The correct arm came with the rough country kit I installed on mine. Depending on the lift you choose, the arm may or may not be included. That is something you will want to ask about if it isnt otherwise stated that the arm is included.
  3. cheyenne_77
    Aug 5, 2002
    38
    The suspension arm is needed for the 4 inch lift , but anything else to retain the full turn circle? /forums/images/graemlins/confused.gif
  4. Scooter
    Nov 18, 2000
    551
    Grandview, Mo.
    Once the steering arm is replaced and the drag link adjusted to recenter the steering its pretty close to the same turning circle.
  5. Grim-Reaper
    7,385
    Atlanta
    Yeah once you have a raised steering arm it should correct back to stock. What will change the turning raidis from that point will be tires size and wheel width and offset. A 31x10.5 inch tire on a stock 3.5 offset 8 inch rim will have a considerably tighter turning radius that a 35x12.5 on a 10 inch rim with the same offset.
