steering correction when lifting
Discussion in 'The Garage' started by mo, Dec 1, 2004.
  1. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    If I put a 4" lift on, would I need a 4" block to correct steering issues, or would a smaller one, say 2.5", be fine?
    D60 by the way if it matters
    thanks
    mo
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I would suggest you to save your money and get a crossover system, one of the best steering mod's you can do, ORD makes a kit, so dose a shope in Auburn, but i forgot thier name WFO customs i think it is, they are in the powere seller forum /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    2.5" would be better than a 4". Maybe a dropped pitman arm instead?
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I can't afford x-over right now although I would definitely rather go that route...It will come in the future.
    thanks
  5. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I have a 4" lift on my 1-ton pick-up, and after measuring the steering knuckle arm to pitman arm height difference, it was 3". At first I used a 4" drop drag link, but the dropped drag link over corrected my steering angle by 1", which may be causing my truck to not handle as good as it could.
    Many people here say dropped drag links suck, and have recommended I go with a dropped pitman arm and factory drag link instead. I recently purchased a 2" dropped pitman arm and factory drag link. With a 3" difference, that will leave a 1" under correction difference, which I hope will handle better than having a 1" over correction.
  6. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    Use a drop pitman arm (skyjacker ca-90) and NOT a raised steering arm. Not enough room w/ a 4" lift for crossover and the raised arm will gove you bumpsteer problems. The raised arm caused bumpsteer on a 10 bolt so a 60 might be a little diffrent
  7. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    Is there a raised arm for a D60?
