steering correction
Discussion in 'The Garage' started by gmcjimmy4x4, Mar 2, 2007.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    Ive got a 91 jimmy with 6" lift. Used to be 4". With the 4" lift , i installed a corrective device that bolts to the top of the knuckle.(sorry not sure what this part is called) Is this enough to correct the geometry, or can you use other parts to help also? Seems like i dont have turning radius that i used to have.
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    You may want to consider crossover. just my $0.02
  3. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Sounds like you put a rised steering arm on. You could also get a drop draglink or drop pitman arm. On my old k5 with 6" lift, I had a rised steering arm, and also a drop draglinl and my steering was pretty good.
  4. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    x2 on the drop pitman arm and raised steering arm if x-over not an option.
    EDIT: http://coloradok5.com/forums/showthread.php?t=197959
