Steering correction
Discussion in 'The Garage' started by UPS, Mar 5, 2007.
  1. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    What is the best a steering arm lift block or adjustable dropped drag link? I will have a 6" lift, Dana 60 front.
    Which brand is better?
    Thanks,
    Mike
  2. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    Anybody have any suggestions?
    Thanks,
    Mike
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the "best" would be to go crossover. if you don't want to go that route i would say a dropped draglink.
    downside to a steering block is your studs double in length and theres alot of force there.
  4. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    I don't have enough time to do cross over right now. I want to build the cross over myself.
    The first mud run is around the first of April and I still need to install the motor, trans, transfer, Dana 60, 14 bolt, lift, install the gears and Detroits and mount the tires on the rims. The motor will get an intake, cam, distributer, headers, and maybe heads and roller rockers. The trans will get a shift kit, pan, and maybe a converter. I need to build drive shafts. I need to clean and paint the lift springs.
    Man that sounds like a lot of work I better get off the computer and get to work.
    Any info on any of that stuff will be helpful.
    Thanks,
    Mike
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    thats a big list to complete in one month. If you want crossover later you might as well spend the money now. any money you spend on the standard push pull setup is going to be a waste.
    if you are going to run a new stall converter then now is the time to do it. nothing sucks more then taking everything apart again to install one when you had the engine or trans out before.
    you need to have a plan for a build of this size, otherwise you never get anything accomplished. write a list of everything you want to do, then put it in order by priority of what has to be done and what you simply want to do.
    go read Manny's thread. That will give you an idea of the time involved and the patience needed.
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I wouldnt use a block.
  7. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    Did the nuts loosen up before it broke? Are there bolts in it also?
