Steering Corrections for a 10" lift.....
Discussion in 'The Garage' started by blazerpro79, Jul 30, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    I've got a raised steering arm on my 5.5" lift... what would you guys suggest as the best way to fix the steering. I bought a set of 10" superlift springs i will be running up fornt. thanks a lot...
    ps im running 35's right now and will probably running 38" radials... not sure what yet though. crossover/hi steer will come with the new tires.
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    crossover or your steering will be a nightmare
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like time for crossover steering when you put those 10" springs in.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I have the steering correction from a superlift 12" kit (drop pitman arm, drop drag link, raised steering arm and 3" steering arm spacer block) that should be available for sale in less than a week or so.
    I would HIGHLY recommend going with crossover if you can at all afford it...
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    sounds like crossover is definatly the way to go... what about hi steer. i am pretty uneducated in the steering department... sorry guys...
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Hi steer moves the tierod above the springs for more clearance. You do not need highsteer to run crossover. and if you still have a d44 or 10bolt, highsteer and crossover is alot to ask from it. its alot of stress on the knuckles. if you have a 60 its much easier/cheaper to do.
  7. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    i have a 10 bolt :doah: . i cant afford to swap it out for a d60 though... i dont think ill have problems in 2wd on the street anyway... the 10bolt would hold up fine.
