Steering Damper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Apr 8, 2002.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Is this the "shock-looking" thing in front of the front axle? Is it also known as a steering stabilizer? Is this just a regular shock?
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Yup - that "shock looking thing" is your steering stabilizer. What makes you ask?
    -Dan
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I can't say that "its just a shock" but it is indeed your steering stablizer
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Nope .........it's not a shock at all. A normal shock will resist pressure from one direction, whereas a steering stabilizer maintains pressure from either direction. Look at it this way- if you used a shock it would be alot harder to turn the wheels one than the other way, right?
    I hope that makes sense./forums/images/icons/smile.gif
  5. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    Well, like a blown out shock, mine is covered in oil. It's not engine oil or tranny fluid or power steering fluid or brake fluid, or coolant. It appears to be leaking and I was going to replace it but I wasn't sure what it was called. Thanks for all the help.
  6. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    You can check out www.rockymountainsusp.com . They sell the TrailMaster coil over stabilizers for something like $80 with shipping. I think the PN is 57201... /forums/images/icons/wink.gif
    -Dan
