Steering Damper?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Stroked72Blazer, Feb 19, 2003.
  1. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Is it possible to overkill with a double damper. 6" lift, 33" tires soon to be 35s
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Not that I have ever noticed/been told. with 33's you can get away with a single but with 35's I would definitely use a double. So, if you went double now, you would be fine and ready for the 35's.
    -Ryan /forums/images/graemlins/k5.gif
  3. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I wouldn't think it would be nessary to run a double set up i would wait till you put the 35's on and go from there if you feel its needed than go for it. It wouldn't be overkill i have seen some people run as many as 4 but it was more for looks not function. I only run a single and have 40" tires with crossover steering.
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I have a Trail Master dual damper system on my Blazer with 32s. It really isn't overkill even for those tires.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I have 35s and only a single steering stablizer and it seems fine. I drove for a while with no steering stablizer when i had to get a new one and it had quite a bit of bumpsteer it felt like but wasn't horrible. A single feels good, never tried 2. /forums/images/graemlins/confused.gif
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have 36's and no dampener on it right now. I need to put one on but I haven't even noticed it missing.
    One bonus to a good steering dampener is that it will take some of the stress off your frame around the steering box...I just don't like any of the double mounts. They all stick out too much.
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I'm with Triaged and Ryan on this one!
    I think two stablers is not needed. On good one will do the trick just fine. As stated already the doubles tend to hang WAY too low for my liking. I have 35"SSRs and run a single Rancho stablizer and it works just fine... /forums/images/graemlins/usaflag.gif
  8. Steve_Chin
    Mar 6, 2001
    1,126
    The Trailmaster setup I have doesn't hang all that low. Maybe a little lower than a single, but the shocks are mounted in opposition to each other at the same height so that you're compressing one while extending the other. I know that I could probalby adjust mine so that I could get it another inch higher, maybe more.
  9. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    I guess my main concern is over powering the power steering. Is that possible?
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I dont know about over powering it. My frame is strenghtned up in the front (not by one of those weld in frame crack kit things), so it doesnt flex all over and put stress on the frame when you turn the wheel, I have Skyjacker dual stabilizers and 42's and mine you can turn with your pinky! No crossover eithr.
  11. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I'm glad to hear that the damper helps. I'm installing one today on my truck. I went to some real soft springs (about 240#/inch) and now the ride is great, but I got some nasty roll steer and bump steer. I installed a swaybar with disconnects to fix the roll steer...problem solved. The bump steer is tolorable, but I was hoping the damper would mellow it out a bit.
  12. Steve_Chin
    Mar 6, 2001
    1,126
    The factory assist setup is so over-boosted it's ridiculous. I have a small diameter road-racing steering wheel from Momo and turning the wheel is so easy that I want to re-valve the box (for better road feel, mostly).
    Of course, the over-boost situation would come in handy in some yukky mud or on the rocks...
