Steering for D60
Discussion in 'The Garage' started by mil_act02, Jun 14, 2005.
  1. mil_act02
    mil_act02 Registered Member
    Jan 19, 2005
    32
    Caldwell,TX
    I was looking for a drop pitman arm for my 83 Jimmy. I have a 6 inch lift with a D60 front. All I can find are raised steering arms for the 10Bolts and steering blocks for the D60. Which would be better the drop pitman arm or the steering block? Where could I find a good deal on either of them?
  2. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    i prefer the drop pitman arm. easyer to install and less work to install.:cool1:
  3. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    the part number for a skyjacker dropped pitman arm is a CA50, as it is only a 2 inch drop, do you already have the raised steering block, if not i have a brand new one that was installed on mine for about 2 days before i went crossover.
    ryan
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    if you want the best setup? try www.offroaddesign.com and get the crossover setup. plus you need a 2x4 box to bolt on your truck. a bit more but worth it. the pics dont do the stuff justice. i have the big kit with all parts high steer. and the stuff is big! the arms are about 1 1/4" thick.
  5. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    I just installed a 60 this week in my 76 shortbed, along with 8in suspension. I installed the block, but think im going to have to install the drop pitman arm also. I still have a pretty good angle.
  6. mil_act02
    Jan 19, 2005
    32
    Caldwell,TX
    steering block
    I don't have a steering block yet. What size is your block? Does it come with the new studs and everything? How much would you sell it for? Thanks for the help.
