steering from a lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Goodolboy, Mar 13, 2003.
  1. Goodolboy
    Goodolboy Registered Member
    Mar 13, 2003
    6
    Utah
    I put a 10" lift on a 87 full size jimmy. Even after recentering the steering wheel, the truck will only turn sharp one way. How do I correct this. Should the knuckle arm that was part of the lift kit be bent to give greater steering?
    Also the truck / steering now wanders. What would help this? An additional dampner / absorber?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Dont bend it, it will weaken it! You need more steering correction, either a dropped pitman arm or a dropped drag link. </font>
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I don't know shaggy, he might be a canidate for cross over steering. And a redneck ram too. If you're running tires that need that much lift then you need hydro assist too.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That would be ideal, but would cost alot more than just adding some more steering correction, especially if he's still on the 10 bolts. </font>
