steering gear 79 wtb
Discussion in 'Parts & Trucks Wanted' started by 4x4k20, Jan 6, 2005.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i need one for my 79 k20. i put one on off an 87 and my hoses wont hook up to it. :mad:
  2. sweetk30
    Nov 1, 2004
    25,550
    543
    horseheads , ny 14845
    hose info
    the old style were 45 flare. the new are flat with oring lip . if possible get pump and hoses from 87 . or make change over hoses from both sets.
  3. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    this is allways the way my luck goes . i thought it fit rite on my truck and wouldnt cost me nuthing. but i just went and bought a rebuilt one for 200 bucs .
  4. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    A good parts house will let you swap the nut out in the back of you’re pump with one that will work for you out of a core they have laying around. That and some new hoses and it’s a done deal. :thumb:
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep swap the nut in back of your pump and youll be fine, the only real problem is the hi side hose it is one piece hose, and you need o ring type end fitting for lo side, me and many other ppl here have fitting and hose end laying around and maybe even an 80-up hi side hose assembly too,
    79 older were flare seat
    80 up o ring
    as you have found out and many others have in the past
    and will in the future
    good luck
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got a gear box off of a 79 and some extra hoses. Let me know if I can help.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I pulled the original steering box off of my '79 K20 when I put in the 6.2L diesel w/hydroboost and had to go to o-ring style fittings (since my donor was an '84). Everything was working good when I pulled it and I'd sell it for $25 plus shipping.
