STEERING GEAR BOX FRAME
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SNOHEAD, May 31, 2000.
  1. SNOHEAD
    SNOHEAD Registered Member
    May 8, 2000
    12
    MT,WEST YELLOWSTONE , GALLITAN
    I JUST FIXED THE GEAAR BOX FRAME BRACKETS ON MY TRUCK (78 BLAZER)AND I WAS WONDERING IF THIS IS A USUAL THING TO HAVE HAPPEN AND HOW DO YOU FIX IT? I ENDED UP WELDING THE FRAME CRACK AND BRACING IT WITH QUARTER INCH PLATE STEEL . WAS THIS THE RIGHT THING TO DO .
    P.S.
    I PULLED ALL THE WEIGHT OFF BEFORE WELDING IT . AND AM IN THE PROCESS OF PUTING IT BACK TOGETHER ,
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    They make plates just for that reason, I havn't had it happen yet but yeah sounds like you did the right thing to me
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Yep. Happens alot. You probably did OK. www.offroaddesign.com makes 2 kinds of braces for the frame by the steering box. One of them is weld in, like you just did and the other one is a bolt in style. The bolt in style is supposed to be stronger, but if yours has already been welded, you might have trouble getting this one to line up.
    '73 K5
    Chevy good...Ford bad
