Steering gear box- Removal help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pookster, Dec 20, 2001.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Someone guide me here. I'm going to be removing the steering gear box this weekend, and putting in a new one. THe old one leaks badly, and also has major play.
    Anyways, the question I have is, Do I just drop the pitman, remove the bolts, P/S lines, and does it just drop right out? or do I have to do something to remove the steering shaft?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Remove the bolts on the shaft and pull up on it and it should come off. Do the rest as you said and it should go easy.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    pretty straight forward
    just do not forget to put something under to catch excess fluid
    and like he said just pull the 2 bolts out of the rag joint and slide toward the firewall
    i replaced mine i about and hour, and now the new (reman) still has way to much play and i have to swap it again on friday
    good luck
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
