Steering gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dumbfounded, Nov 29, 2000.
  1. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I've got a problem with my steering gear. From what I understand the later models had an o-ring seal for the high pressure hose and the older had a "compression" fitting. Is there anyway to tell a 78 compression style steering gear to a later model with o-ring fitting. My problem is my older style fitting doesn't bottom out in my steering gear and needless to say leaks like you wouldn't believe. The metal part of the high pressure hose moves up and down on the gear with the fitting screwed all the way down.. If it is an newer type can I just change the pump and hose to a newer style?
    Love, Peace, and Hair Grease...........
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    If the hose fitting is bad, just get a new hose, I doubt that anything is wrong with your box. If you have an o ring style box in there, have a hose shop make you a set of hoses that has the compression fitting on one end for the pump, and o ring fittings on the other for the box.
    ken
