Steering geometry for a 10" spring lifted Blazer.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, Apr 9, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Steering geometry for a 10\" spring lifted Blazer.
    Well I opening this up to a forum here because at work (4 Wheel Parts) I am getting so many different ways to get my geometry back. Heres the deal I have already purchased a pitman arm from super lift when I did the 6" lift. When I went 8" I just adjusted the drag link and it seems to be fine now. But now I have 10" springs and well what do I do now? guys tell me the drop drag link is garbage, some say the steering spacer is a good way to go raising it 3" near level.. what do you think?
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: Steering geometry for a 10\" spring lifted Blazer.
    I personnaly dont like the drop drag links. Id go w/ the drop pitman and lifted arm w/ the block. The drop links tend to "twist". Or a cross over. /forums/images/icons/tongue.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Dan-
    With a 10" lifted spring I would honestly be looking at doing crossover.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    cross over with a drop pitman and a high steer setup.
    it will make you turn great.
    grant
  5. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    yes the concensus I get from the shop is a cross over steering set up which is bank for now but in the future.
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Dana 60 and crossover.............../forums/images/icons/laugh.gif
    Even if you keep your 1/2 ton front end crossover is the only way to get it to turn properly and correct the geometry.
    D60, D60, D60...........still going up to 42's, right?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I would use the current drop pitman arm and a 6" Skyjacker raised steering arm.
    This will still leave the drag link down approximately 2", but at least it won't be as bad as if you ran the 4" raised steering arm. 2" of drop in the drag link is not that bad.
    If you still prefer to get the drag link horizontal, I would go ahead and use the 2" drag link, like from Skyjacker or Superlift. At least with the 2" drag link, the angle is not as severe as the 4" raised drag link. 2" drag link is just a slight bend in it, and I don't see anything wrong with using this drag link. Just stay away from the 4" link.
    The biggest problems with the aftermarket drag links are the ends, which wear out too fast. These pieces need to be changed and new ones installed, constantly.
    I had the 4" drag link once and never again. The ends probably lasted me 6 months, tops. New ends from Superlift were $50 per end. /forums/images/icons/tongue.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    level is not the objective in steering angle.
    the drop link will help centre the rod end
  9. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Well I spoke to skyjacker and since I have the pitman arm the drop steering arm not drag link will give 9.25" of adjustment which will work great for what I am doing..
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it will bumpsteer towards oncoming traffic when you hit frost heaves BTDT
