steering help?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by roostr3269, Jul 20, 2001.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    i have a 1972 jimmy with 8 inch susp. lift, and 3 inch body lift. all steering components are stock, and u can imagine what its like. trying to keep it in a straight line is a job, especially with the bumpsteer. i got a price from ORU and they quoted me $850.00 for just crossover steering for my application, not to mention new 2wd steering box. If any1 out there knows any1 with a better price or alternate solution without reducing lift would be greatly appreciated, thanx roostr32 p.s. dana 44 up front, with 39 inch mickey thompsons around
    live to wheel, wheel to live
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are looking for cheep you could keep the stock push-pull steering and add a 4" raised steering arm and a 2" drop pitman arm. For about $100 you could have the steering almost back to normal on the street. You could also make your own cross-over steering.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    read this if you haven't
    <a target="_blank" href=http://coloradok5.com/crossoversteering.shtml>http://coloradok5.com/crossoversteering.shtml</a>
    there are quite a few posts in the ORD section covering crossover steering...i don't know how much all the necessary parts cost when purchased from ORD
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  4. roostr3269
    Jul 2, 2001
    305
    michigan
    thanx alot guys, i am gonna get with my buddy, i call him mcgyver, he can make pretty much anything, thanx again, ill keep u posted
  5. Thrashed68
    Thrashed68 Registered Member
    Jul 22, 2001
    8
    Or.
    I saw a cross over set up on a 76 once that was a bit different. The guy used a 2 wheel box with a dropped pitman arm, and made his own drag link. By turning his tie rod around and using the factory steering stabilizer hole as the connect point. I think there was a Heim joint there. As far as how it worked, I cant say as I never drove it. But he said that it completly took care of all his bump steer... Seems to me that would be a bit cheaper then a complete knuckle swap etc. Just my 2 bits.
    Skin grows back, Parts cost money!
