Steering HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Mar 18, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Today when I was pulling into a parking lot I think my steering took a turn for the worst. ha ha =-( I have always heard clunks in my steering but today when i turn the wheel and I'm not moving it's like the steering gives out. I can turn the steering wheel about half way around and the tires respond, but then theres like a grindy, clunky, noise and the wheels no longer respond, as if something is slipping. Is this the steering gear box? Could it possibly be time for a new one? any thoughts?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Check for cracks in the frame around the steering box...Common problem on K5'S..Dan
  3. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Theres no crack there. I just put a ORD steering box brace on a month ago. I think this is a problem somewhere in the steering like the box. Thanks
  4. dyeager535
    26,975
    Put the tire up against the curb, pop the hood, and have someon turn the wheel while you are crawling all over the truck looking at all steering components.
  5. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    I fixed it! It was a silly thing. When I put my new headers on I had to remove the power steering pump off the block and when I reattached it the belt was to loose, so when the pump was under pressure the belt slipped. Thanks for the help.
