steering Issue
Discussion in 'The Garage' started by CrazyJoe73, Mar 11, 2006.
  1. CrazyJoe73
    CrazyJoe73 Registered Member
    Mar 11, 2006
    7
    New Hampshire
    I have a 1972 k5. I am it lifting 6" , swaping a dana 60 in it and moving the axle forward 2" with 38.5" tsl's. I am wondering if cross over steering will fix the steering geomitry or will I have to do something else?:dunno:
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Moving the axle forward like that, crossover is a must. You cannot use the original steering setup. The arm will be too short and near vertical.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    And besides for moving your axle forward, whenever a truck is lifted 6" or higher, you will get bump steer with "push-pull" steering; no matter what steering correction modifications you do to the factory drag-link.
    I just put a set of Tuff Country 6" lift springs on the front of my truck. I corrected the stock "push-pull" steering with a 2" dropped pitman arm, and a 3" raised steering block. My truck's handling is great as long as I am on smooth road, or small bumps. But whenever I hit a bump big enough, I get bump steer like crazy. And nothing short of putting a cross-over steering system on my truck is going to fix it.
  4. CrazyJoe73
    Mar 11, 2006
    7
    New Hampshire
    Thanks! I knew that I would get an inteligent ansewer here. Up here in the north east every one looks cross eyed at you when it comes to Chevy stuff, it s all Jeeps with Chevy drive-train here.
    So the cross over should do it. As long as I buy a quality set up like Dynatrac or something?
  5. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    ORD and several others make kits. Several people here, including me, have made our own.
  6. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    One of everybody's favorite companies for getting a cross-over steering system is Off Road Deaign (ORD). Here is a link to their web site.
    http://offroaddesign.com/Dana60crossover.htm
    I am thinking of going with a cross-over system from a company called Sky Manufacturing because I allready have a Sky Manufacturing Heavy-Duty tie rod.
  7. CrazyJoe73
    Mar 11, 2006
    7
    New Hampshire
    Thanks for the help!:bow:
