steering issues and 52" springs?
Discussion in 'The Garage' started by four_by_ken, Sep 13, 2004.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    steering issues and 52\" springs?
    I seem to be reading about some problems with the 52s and the steering? Currently I just have cross over.
    Are the issues with high steer, or also with cross over when going to the 52 inch springs in the front?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Re: steering issues and 52\" springs?
    It doesn't really have anything to do w/ the springs... just the axle placement. If you move the axle forward 2" as the 52's do (w/o moving it back w/ a 0 rate) then if you run hi-steer the TR and DL will bind up. If you just run crossover you are golden.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    When i spoke to Stephen i asked because i have mine 3.5"s foward and there is no way to run hi steer, he does sell a tie rod that that is burlly as hell /forums/images/graemlins/woot.gif
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you will only need the crossover, the stock steering set up will not work since you will have so much flex.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there is no way to run high steer with HIS stuff. I am gonna go with WFO concepts steering arms, puts the tie rod behind the axle. http://www.wfoconcepts.com BlueTorch Fabworks makes some that put the tie rod behind the axle as well.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm using longer springs, pushing the axle farther forward and all I had to do with my little dana 44 was drill one more hole in the steering arms. I swapped the tie rod and drag link locations..they can't hit each other now.
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I already have cross over... so I think I should be good.
