steering issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Apr 16, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    62
    florida
    New 6'' lift with 4'' steering arm and 2' drag link.Major pull to the right and truck tracks to the right.At a dead stop , if i touch the brake pedal the steering wheel will move.Is this alignment or what??Tried to get aligned today but my sway bar wasn't seated all the way.Will try again tomorrow.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Sounds like a caliper is sticking. Jack up the front end and apply the brakes and then rotate each wheel by hand. They should rotate relatively easily. That's where I'd start.
  3. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Check the u bolts. Mine pulled to the right because the u bolts weren't tight. Hope this helps.
