Steering line fittings, O-ring and pump question
Discussion in 'The Garage' started by dremu, Apr 30, 2006.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I'm used to the old style, flared-end hoses.
    My new setup is O-ring, and apparently the fitting on the box requires an 18mm wrench (an odd size, I might add, lots of 17's and 19's but few 18's) ... but the one on the pump sure seems like a 5/8 (or is it a 16mm?)
    :mad: :eek1: I am starting to LIKE old tech.
    Took the pump proper out of the reservoir as I'm juggling parts to convert to hydroboost. Is there any magic juju to the seal around the pump on the front, or do I just clean it and carefully insert the pump into the reservoir?
    -- A
  2. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    i always use a good old crescent wrench for p/s line nuts
    cant ever seem to find anything to fit any of them except the ones at the steering box
    but even then i just use a crescent and a hammer on them too because about 2/3 of the time i cant find anything to fit them either, not fast enough for my liking anyways, digging for certain tools is a PITA usually, pisses me off often, some guys have concrete and a shop and real boxes and real drawers and other cool stuff, and well theyre lucky. heh
    heres my fancy state of the art garage:
    good luck
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Changing "cans".???
    I've swapped a different "canned ham" P/S resiviour onto the one in my 305 motor in my 79 C10..I just cleaned everything with brake cleaner,used no sealer,just a bit of grease on the big "O" ring to help it slide together..it didn't leak there after the swap was done..but the next day I had to remove the pump again..and braze a tiny pinhole shut on the bottom of the "good used" resiviour I just put in the day before!..:doah:--I love doing everything twice...:mad: .
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Anyone got pics of the different fitting styles? I have no idea what the visual clues are to differentiate between the two...:doah:
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    The 'O' ring style has an 'O' ring...
    :p:
    Kinda like an O.R.B. hydraulic fitting.
    Rene
  6. dremu
    Feb 27, 2000
    15,954
    445
    O-ring style is here:
    http://coloradok5.com/forums/showthread.php?t=172437
    And the older one is your basic flared end, looks like a brake line or whathaveyou.
    -- A
