Steering Linkage Identification
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Jun 4, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Hi all - I found that one of my steering linakges is worn, but I need to know exactly what to ask for... so I need some help. There's a linkage coming off the bottom of the gear box (pitman arm I presume), that connects to another linkage that runs front-to-back. It connects to the steering arm on the drivers side. What is this linkage called. I think the Haynes Manual referred to it as a 'connecting rod'. Thanks, Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    its called the draglink i think
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Drag link.
    '73 K5
    Chevy good...Ford bad
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes sir, that's your drag link.
    This wouldn't be a bad time to check your tie rod ends either.
    -- Mike
  5. beefcake83
    Jun 24, 2000
    240
    Alaska
    Thanks... So far my tie-rod ends looks good, but I'm getting ready to order a Rock Rod, and will look at them closer. - Gary
    Gary Graham
    Eielson AFB, Alaska
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I thought it was called a steering rod?? Isn't the drag-link the bar between the tie-rods, the one that links the two front wheels?
    If it's worn, can't you put new balljoints in it? Mine's a little sketchy too, and I just figured eventually I'd replace the balljoints on it. This may be a little cheaper, and not screw with the box-to-wheel alignment for you. If it's even possible to swap the balljoints in it!
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    No, the one that links the two front wheels is the tie rod. On some early tie rods, you can NOT replace the tie rod ends because they are manufactured as part of the tie rod. Newer ones (I think 82-up or someting) has a center bar and two removable tie rod ends.
    I think it is a cheap and better proposition to buy a rockrostomper tie rod. They are VERY reasonable and you can go to Autozone and get lifetime tie rod ends. Just be sure to order the steering stabilizer kit for about $25.
    -- Mike
    BTW, the drag link is is much shorter link between the pitman arm (on your steering box) and the steering arm (on the left steering knuckle.)
  8. johnnysjimmy
    johnnysjimmy Registered Member
    Apr 23, 2001
    47
    DRAG LINK!!!!!!!!
    73' GMC Jimmy 8" lift and 35" tires.....14 boltff and big 10 bolt on the way
