Steering off after wheeling?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85scottsdale, Feb 22, 2004.
  1. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I have noticed that it seems like my steering will be become off-center when I do some off-roading stuff. Alignment doesn't seem to be affected, nor does the drag-link seem to change. I'm thinking something about the steering box or maybe my pitman arm is slipping on the shaft? That my only guess right now. I have one new drag link end and the other one seemed nice and tight. Anyone had this problem? I'm hoping I won't need a new gear box but I really doubt that unless the pitman shaft is screwed up?
  2. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    Frame crack, or loose box bolts. Less likely but possible is a broken center pin in the front leaf pack.
    Rene
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, that used to happen to me all the forkin time! Then I tightened down the loose steering box bolts and installed a brace at the same time and it went away... [​IMG]
  4. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Just fixed my cracked frame, i'll check to make sure the bolts haven't loosened up. Also have new springs in the front from my lift, they haven't even been off-road.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    If the center pin size is smaller than the hole in the pad it will allow a little movement and if you have stock steering it is worse.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine did that for the first two years I owned mine.........then in early 2003 my tie rods went south and ended up getting new tie rods, draglink ends etc. When it went bad it felt like tire was folded under truck, but they didn't actually break /forums/images/graemlins/k5.gif
  7. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Problem solved! The steering box bolt were loose. Maybe I should put some loc-tight on them.
  8. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I had the loose bolt syndrome. My box loosened up twice on one trail last time. That was the end of that. I got the next longer bolt and now have lock nuts on the outside.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    [/ QUOTE ] That is a great idea /forums/images/graemlins/thumb.gif
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    Yeah that happened to me before, the centering pin was the culprit.
    But then I had all the others one time or the other, from cracked frame to loose bolts to bad ball joints to slop in the box and finally the rag joint.
    Now i have all the reinforcements and the tightness and I will be upgrading my rag joint to U joints, I hate slop in the steering.
    /forums/images/graemlins/eek.gif
