Steering Play?
Discussion in 'The Garage' started by kyser_soze, Feb 13, 2005.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I just bought a 1997 k3500 with a 6" procomp lift kit. Driving the truck is a real chore because there is steering play in the wheel. I would like to know what to look for in my steering system before I investigate the problem. Is this common with a 6" lift and 315 tires for a 1ton duelley? It does have 188 thousand miles so The first thing I will look for is the ball joints but after that?:dunno:
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    have someone move the wheel for you with engine off and watch for play in frt end parts. thay eat idelers and pitmans bad. then take floorjack and lift frt up by the lower controlarm and take long bar and put under tire and pull up and watch for play in balljoints and then move tire by hand in and out with hands at 12oclock and 6oclock positions. this will tell you all you need to replace. thay eat balljoints also. and if the balljoints are still riveted in thay are origanal and will most likly be gone. hope this helps you.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Steering system check for full-size IFS Chevy trucks (With or without EVO) by “ReadyMix”
    Listed below are the components you will check in the order you will check.
    ~EVO System is discussed at the end.
    Wheel Bearings
    --Place the truck on jack stands.
    --Spin the wheel around and listen for any noise other than what is caused by the brakes.
    --With one hand on the top and the other on the bottom of the wheel, move the wheel in and out on the spindle. If there is any noticeable movement the wheel bearings will need servicing or replacement. Wheel bearings can only be serviced on 2WD trucks
    Ball joints
    --Remove wheel
    --Place floor jack under the LCA and lift slightly.
    Upper Ball Joint
    --Using a screwdriver or pry bar, pry up on the UCA and look for slop on the ball joint.
    --Wiggle the knuckle around and again look for slop in the ball joint.
    Lower Ball Joint
    --Measure the distance between the tip of the ball joint stud and the back side of the ball joint (or grease
    fitting if installed).
    --Now lower the jack and re-measure the ball joint again. If the difference is more than 3/32” you must replace the lower ball joint.
    If either of the ball joints are bad I recommend changing them both while you have it apart.
    Now reinstall the wheels and lower the truck.
    For the remainder of the check you will need the assistance of a friend.
    Inner and outer Tie rods, Pitman arm, Sector Shaft Bushings, idler arm and associated bushings
    --Remove the front differential skid plate and cross member skid plate if so equipped.
    --Have your friend move the steering wheel back and forth a few inches. Not enough to move the tires but enough to put force on all of the steering components. It may or may not be necessary to have the truck running for this. I usually leave the engine off with the key in the run position.
    --Look for any play in the above listed components.
    The sector shaft is what the Pitman Arm attaches to on the steering box. The sector shaft should start to rotate a little but should have zero side-to-side movement. Side to side movement indicates that the sector shaft bushings are bad.
    The idler arm is on the opposite fame rail but in the same location as the steering box. The check for the idler arm mount is the same as for the sector shaft.
    There are 4 tie rod ends to check, 2 on each side. One attaches to the center link and the other to the steering knuckle. If there is any play they should be replaced. The tie rods should also be checked by pushing up and then pulling down on them while looking for play.
    All of the above listed parts are relatively simple to change if found bad with the exception of the sector shaft bushings. If they are found to be bad it is easier to replace the steering box (if you don't know what you are doing). Usually when they are bad the truck will experience what is known as “DEATH WOBBLE”. It is much like bump steer except it is uncontrollable usually between 20-40 Mph.
    Three things can cause a crooked steering wheel.
    1.The tie rods ends were not properly adjusted for steering center when the truck was last aligned.
    2.The Keyway splines are twisted on the input shaft of the steering box (not easily repairable, steering box must be replaced or rebuilt)
    3.The splines on the sector shaft could be twisted. Keep in mind that the standard Chevy Saginaw type steering gear has a 16:1 reduction ratio. So if the splines were twisted by only 2 degrees the steering wheel would be off by 32 degrees. I don’t know about you but I have not been able to visually tell if the splines are twisted by that small of an amount.
    Free play in the steering wheel should not be adjusted by messing with the lash adjuster. This is to set the preload in the steering gear. If you don’t know what you are doing here I suggest that you leave it alone.
    On the top of the steering box you will see 4 hex head 10mm bolts holding on an access cover. In the center of the access cover there is an adjustment screw with a counter tightening nylock nut.
    The following adjustments must be made with drag link disconnected from pitman arm and flange removed from worm shaft.
    Loosen lock nut and turn lash adjuster screw all the way in (clockwise), then out (counterclockwise) three turns. This will remove load imposed on worm bearings by close meshing of rack and sector teeth.
    Using a socket on steering gear worm shaft, turn shaft from one stop all the way to the other carefully counting total number of turns.
    NOTE: Do not turn hard against stops when drag link is disconnected as damage to ball guides may result.
    Turn the shaft back one-half total number of turns to center position and using an inch-pound torque wrench, measure pull required to keep worm shaft in motion through center position. This should be 1-1/2 - 5-1/2 inch pounds. If indicated pull does not lie between given limits, make the following adjustments:
    a. Loosen lock nut
    b. Turn adjuster until required resistance to pull is reached.
    c. Tighten lock nut and recheck pull. It must lie between limits specified after lock nut is tightened.
    Note: Turn lash adjuster screw clockwise to remove lash and counter-clockwise to increase lash from gear teeth.
    EVO System
    The EVO system automatically adjusts the required steering effort in relation to engine RPM or vehicle speed. Delphi’s “variableeffort” steering systems incorporate a controller (The sensor on your steering column) that varies electrical current to the actuator device (The EVO valve mounted in the reservoir of you PS pump) with changes in vehicle speed.
    The Electronic Variable Orifice (EVO) system changes steering effort by regulating fluid flow from the power steering pump.
    During parking maneuvers, the actuator provides high pump flow for easier steering effort. At highway speeds, the actuator reduces flow in proportion to vehicle speed for improved highway feel and stability.
    If power to the solenoid or control valve actuator is lost, the valve keeps the bypass circuit closed so full power assist is provided under all driving conditions. The only indication of trouble, therefore, might be a loss of road feel and/or increased steering sensitivity at highway speeds.
    It’s important to remember that variable-rate power steering only reduces the amount of pressure that reaches the steering gear at higher road speeds. The only way it could reduce power assist at low speed would be in the unlikely event the actuator or solenoid valve failed in the open position. This could cause a noticeable reduction or loss of power assist.
    Troubleshooting the EVO sensor
    First, disconnect the three-wire connector from your steering wheel speed sensor.
    Next, with your key in the OFF position, use a digital multi-meter to test for resistance between your CKT 1057 (ORN/BLK) and CKT 1059 (LT BLU) wires.
    Then, rotate your steering wheel slowly from lock to lock and record the highest reading.
    [font=&quot]If the reading is above 12K ohms, you'll have to replace your steering wheel speed sensor and bearing assembly with a General Motors sensor kit (P/N 26064468), $36.19 from WWW.GMPartsDirect.com at time of writing.[/font]
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    thats a lot of work to do for just checking the frt end out. and we do it my way all the time at work and no comebacks for problems. there is some good points there but lots of extra work in my opinon. for just the frt end parts check over section. just need a light to look at parts and a buddy to move things and a jack and prybar.
    good post tho. just lots of extra work in my opinon for frt end check over section.
  5. readymix
    May 30, 2004
    6,706
    26
    It is definatly lots of extra work. However think about the intended audience.
    I wrote it for non-mechanic types. Most people that are on CK5 or other BBS's could do that and more from the top of thier head. I was just getting lots of PM's on other forums about steering systems.....so i did i write up.
  6. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    Thank you very much guy's. I will print off this post and perform the checks when the weather breaks, It's raining here now. I will not drive the truck before doing these checks just to be shure that there is nothing wrong that can go bad, that damn Murphey.
  7. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    well i dont konw if this applies to your year truck but mine had alot of play after changing out ball joint, tie rods, and drag link all it was was that my steering box had come loose tightened her up and it all good now
  8. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    I'd have a look at my tie rod ends(one at each wheel spindles) and then the ones on the link that hooks up on your pitman arm. I know my truck's got all its play right there(pitman arm tie rod ends).
