steering problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solid454, May 12, 2000.
  1. solid454
    solid454 Registered Member
    May 4, 2000
    31
    CA, USA
    I went muddin the other day and now when i start to brake it pules hard to the right.i think i might know what it is. i need to replace the copper washers around the bango bolt (i think thats what it is called) on the front left brake line. also i went into a puddle my clutch got a lot softer. if any one could tell me what happened and what i need to do to fix it.
    BIG HEAVY AND MEAN
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    You might just need to clean the brakes out. If you have drum brakes on the rear, they can get filled with mud and cause pulling.
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    clean out your brakes , repace copper washers, replace fluid in the entire system (use DOT 5) if you don't have ABS, And check to see if bellhousing cover is still on-if it's not get one it will keep out the water and mud. Even if the cover is in place see if there are open gaps that might be sealed with RTV like silicone .
  4. 76 jimmy Az
    76 jimmy Az Registered Member
    Mar 14, 2000
    35
    Tempe, Az
    HEy when it rains around me i love to go through puddles also and i also feel that the clutch is alot softer after goin in the water. However, it eventuallly went away. I dont know why?
