steering problem
Discussion in 'The Garage' started by hidesertwheelin, Nov 26, 2006.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    My steering on my suburban it right after I lifted it. I can turn the wheel to the right only 1 3/4 to 2 turns before it locks. When I tunr the wheel to the left, it turns all the way. I didn't have this problem before I installed the lift. Do I just have to adjust my drag link? Our do I need to pull the pitman arm and re-install it? My pitman arm is on the right position, so I know that isn't the problem, Plus we never removed it when we installed the lift.
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    How much lift?
    (edit: read your sig :doah: )
    Raised steering arm.
    -- A
  3. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I forgot to list I have a 4" raised steering arem installed. Oh ya and I moved the axle forward 1" with the zero rates.
  4. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    If you moved the axle forward you will need to adjust your drag-link.
