Steering Problems after Lift HELP
Discussion in 'The Garage' started by fwc, Nov 6, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    Just installed Tuff Country 2" HD front springs and 2" rear springs. I got almost 4" of lift on the front, 3" on the rear. My steering wheel is off center now, about 45 degrees to the left. Do I need to lengthen or shorten the drag link? Should I get a raised steering arm meant for a 4-6" lift? Any suggestions would be greatly appreciated! Thanks
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I don't think you need a steering arm right now. They springs should settle a bit. There is an easy way to center your steering wheel.
    1. Jack up the front of the truck and put the axle on jack stands.
    2. Start the truck. The steering gear is self centering. It will automatically center itself. The wheels will be pointing to the left.
    3. Turn the truck off.
    4. Loosen the bolts on the adjusting sleeve on the drag link and start lengthing it till the wheels are pointing straight forward.
    5. Tighten the bolts on the adjusting sleeve.
    This will get you pretty close until you take it in a get it aligned. They'll prolly have to adjust it again slightly, but it should be liveable till then.
  3. fwc
    Nov 2, 2003
    84
    Northern Virginia
    Thanks for the input, I will give it a try in the morning. Anyone else have input?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    he is correct
    draglink needs to be longer
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, DON'T get the raised arm....trust me. Bump steer city!!
