Steering problems After Lift
Discussion in 'The Garage' started by splatzone, Jul 26, 2006.
  1. splatzone
    splatzone Newbie
    Jul 26, 2006
    Yakima WA
    Ok guys i have a 78 blazer 6in lift springs all the way around.
    38 swampers.
    it likes to pull to when i hit bumps. and when i am changing lanes it will be hard moving over then when i get half way it just goes really fast over..
    I have replaced the Steering stabilizer, ball joint on driver side. steering knuckle after the bolts broke off.
    I have installed the drop pitman arm from Super Lift, and the raised steering arm. and still same problem
    And the other problem is in my drive train when I slow down I get a vibration and same when I speed up at slower speeds
    I have replaced ever single U Joint that I can it was fine for couple days and same problem again
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    How does your frame look where the steering box connects? Are there any cracks?
  3. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
    Are you running the stock push-pull steering? If so the drag link should be as level as possible. Are you running the stock driveshafts? Have you dropped the transfer case any? Do you know what your pinion angle is?
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    your pinion angle is probably too steep you need degree shims to point the rear axle up towards the t-case
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Welcome,
    Like the others said, check for cracks in the frame around the steering box, check for loose tie rod ends and drag link ends, check to make sure the draglink is perfectly level, check alignment (primarily castor angle).
    The vibration is most likely caused from too much angle in the u-joints, or un-matched angles in the u-joints (Example: the u-joint at the transfer case is a steeper angle than the u-joint at the axle)
    Good luck!
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Good question? I always thought it was level to the horizontal....... please correct me if I'm mistaken.
  7. splatzone
    splatzone Newbie
    Jul 26, 2006
    Yakima WA
    thanks for the suggestions.. we looked at it today.. it got a clicking nose from the box area. were putting it on the rack today to check it out.. the drag link i got the drop one it's not totaly lvl but i noticed on the arm for the steering going to the other tire needs a new joint moves allot..
