steering problems help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4k20, Nov 14, 2006.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i have a 79 k30 with an 8 inch lift and a 86 k20 with a 2 inch lift .. both are making poping sounds when you turn the wheel from right to left mostly to the left when its pops i have looked and cant see whats doing it . i can see the left spring flexing a good bit . but i cant seem to find where the pop comes from . has anybody else had this problem that can tell me whats wrong? i am sure someone else has had this problem
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    sounds like balljoints but being as its a k30 it doesnt have any... could be some loose tie rod/ draglink ends...
  3. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    Have you checked the frame behind the steering box? They like to make that sound as the box forces one piece of frame past the other...
  4. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Have someone turn the wheels while you keep an eye on the frame where the steering box bolts on. My frame didn't appear cracked and i looked pretty good but when i had a friend turn the steering wheel i about crapped my pants when i seen the steering box pull away from the frame almost 2 inches. :yikes:
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Plus if you do this you will see what is wrong if not the frame.
    It could be a spring centering pin that is sheared and the axel is moving back and forth on the spring.
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Check the pitman arm.I had one come loose and it stripped...
  8. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I also had noise coming from a pitman. It was the Superlift pitman from ORD, when I installed it I cranked that bolt for all I was worth but still wasn't happy with the spline depth/engagement or how the thread engagement on the nut. When I swapped my Alcan's under the truck I was also checking everything else for loose, missing or busted and noticed the lock washer on the pitman arm nut was not compressed anymore. :doah:
    I got about 4 or 5 turns on that nut and now I'm satisfied the pitman arm is correctly seated.
    My theory is there may have been a burr on the splines on either the arm or the box not allowing full engagement (until it was driven for a while :crazy: )
    Anyways, my mystery clunk is gone now.
    Rene
