steering problems
Discussion in 'The Garage' started by big dan, Apr 19, 2007.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    The other day I was driving my truck and the power steering pump locked up. I took off the belt so I could get it back home.
    Today I replaced the power steering pump. Now it will steer to the left but it wont steer to the right. It will physically steer but its real hard, like not having power steering. so I have power steering to the left and manual steering to the right.
    anybody know where my problem is? thanks
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I suppose it would be possible that when your pump went out it fried your gear box, or visa versa. It's been my experience that usually when you have power one way and not the other it is the steering gear, if no power both ways it's usually the pump.
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Did you bleed the system? Jack the front end up and turn it on. Turn the wheel back and forth several times. The air will find it's way into the pump and your problems are over. remmeber to check the fluid level after/while doing this.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Read this before you bleed the brakes: (Click on the middle two pages to enlarge)
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    thanks guys. Ill try bleeding it first. Im betting its the gear box but maybe Ill get lucky.
  6. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Let us know.
