steering problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JerseyBlazer, Apr 3, 2002.
  1. JerseyBlazer
    JerseyBlazer Registered Member
    Mar 18, 2002
    28
    New Jersey
    i replaced my tires on my truck with 12-15 (33x12.50x15) denman ground hawgs, now the truck wanders severely on ruts in the road. i replaced the steering stabilizer and still no change. i cant figure out what is going on. all the suspension components were replaced 3 months ago. this problem started immediately after i replaced the tires, i the balanceing and rotated the tires and its still the same! any ideas anyone?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    have you checked the tire pressure?
  3. JerseyBlazer
    Mar 18, 2002
    28
    New Jersey
    i tried the tire pressure at 30, 35, 25 its stays the same, just a little bumpy at 35 psi
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Are the tires bias-plys? If-so, it's a common problem and is part of the wounderfull world of bias-ply tires. (do they follow ruts?, even un-seen ruts?) Also, . A taller/wider tire will feel different, but shouldnt be un-safe to drive.
    Drive it, get the 'em broke in a bit. Then have the alignment set.
    I would sink in as much Caster as possible, specs call for +8 degrees, thats hard to get, but the more Caster you can get, the less it will try to swerve.
    Again, don't expect bias-ply tires to act like radials, they are different and wil act to road conditions differently. (I'm pretty sure Ground Hawds are bias-plys).
  5. JerseyBlazer
    Mar 18, 2002
    28
    New Jersey
    unfortunatly the hawgs are bias ply. i will drive it awhile and get the alignment done. thanks for your help, i hope it works
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Get used to it. My 14.50 SSR's do the same thing and they are radial's. It has alot to do with the width of the tire.
  7. JerseyBlazer
    Mar 18, 2002
    28
    New Jersey
    im going to try the alignment, if that dont work im just going to live with it. thank you for the info.
    pete
  8. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Not just that they are bias ply, but they are directional treaded. Anyone who knows about directional tread will tell you, it will follow a rut/crack/drift like a white on rice. I was towing a boat when I was "forced" to "remember" this. Thank god for waterproof seat covers/forums/images/icons/laugh.gif!!!!!!!!!!!!!!!!!!!
