steering problems
Discussion in 'The Garage' started by wasted wages, Dec 15, 2003.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    My 97 GMC yukon has developed a steering problem ,the truck is a 2 door 4x4 and is bone stock. the problem is the steering is very jerky around the "netural"position when driving in a straight line,,as soon as you give a little correction (right or left ) the steering wheel moves and then the truck jerks like the steering is "catching up "
    I've inspected the tie rods and steering linkage and every thing looks tight except some slack in the pitman arm from the steering box.I tightened the steering box adjustment
    but that did not seem to help.Is there any part that normally wears out that could cause this.Does GMC use speed sensitive steering,and if so could there be a problem with it causing it to act this way??
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Check your power steering fluid.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    it sounds like the pitman arm is changing the toe in which is giving you the undesired steering. also check the idler arm. take a floor jack and get the weight off one front tire, with the steering wheel locked, move the lifted tire left to right. watch the center tierod link to see how much it moves on the pitman and idler arm.
