Steering pull with hubs locked
Discussion in 'The Garage' started by Mastiff, Mar 6, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I normally leave them unlocked but today I accidentally left my front hubs locked and cruised down the interstate. With it like that, I've got a pretty decent pull to the left. I've got an Auburn LSD up there. Any thoughts on where I might start looking?
  2. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I also see that my T-case blew out a bunch of fluid. Is this normal when you run them with the hubs locked (but 2WD) on the interstate?
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    never had it blow out fluid except for the time i had to pull my rear driveshaft and limp home in front wheel drive....
    I don't know about the pulling... i was gonna ask if it was because the diff is on the passenger side but since you have a limited slip i don't see how that could happen.
  4. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Tires
    Check your tires air pressure, that could maybe cause that.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I put a ton of miles on my truck in the winter with the hubs locked but in 2wd. It doesn't hurt anything.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Maybe I overfilled the T-case at some point. I don't figure I'm hurting it, but I have the breather routed to the engine compartment and it's annoying to blow fluid out in there.
