Steering pulling on acceleration
Discussion in 'The Garage' started by AZPiNsTrIpEd, Dec 12, 2005.
  1. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Like the title says any time I'm going down the road and give it gas, my truck pulls to the left, and when I let off it does the same thing. Which makes it look like i'm swerving all over the road. It also does it mildly under hard braking also. My power steering box is new with standard push-pull steering. Truck is an 84 Blazer w/ 4" lift and 35's 44/14ff combo. I'm thinking this is a ball joint problem but not sure. Let me know what you guys think
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    99% of steering issues come from worn out tie rod ends, draglink, balljoints, or a combination of all three. Do a really good inspection of all your front end components and you'll see what needs replacing. It could also be a sticky front axle u-joint, but I highly doubt it.
    FWIW, new balljoints and drag link ends tightened up my front end a lot and basically eliminated all the wandering issues I was experiencing.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Ya when i first got my truck my steering was as loose as a 40yr old hooker! lol we replace my tierod ends and links. This helped ALOT. then i got my truck aligned and the tires balanced. now i have almost no pull at all.
  4. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Since you mention a 4" lift, retighten your axle u-bolts. They sometimes wiggle loose after wheeling, or if they have just been installed recently.
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Did you put a raised steering arm or a dropped drag link on it when you lifted it?
    If not, the steering geometry is off, and when you accelerate, the weight shifts to the rear, causing the front to lift. This effectively pulls the steering knuckle forward, causing it to go left. When you back off, the distance closes, pushing the steering knuckle back, causing you to go right.
  6. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Along the same line as fatbob, I'd also check all the center pins in the spring packs. I had a busted rear one and had a nasty pull under acceleration and braking only.
    James
  7. AZPiNsTrIpEd
    Jan 24, 2005
    289
    3/4Tonsville
    I used a raised sterring arm and have also gone through and checked all of things 79Jimmy and fatbob mentioned. I think its my drag link ends. I'll run a search and see what good brands are to use. If you have any reccomendations feel free to let me know.
    Thanks,
    Justin
  8. Can Can
    15,552
    136
    Moog front end parts all the way, baby!!!!! :thumb:
  9. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    Do you have a locker in the rear? Check you tire pressure and make sure they are even. I have a detroit and got a slow leak in one of my tires. It was jumping all over the road when I sped up or slowed down. One tire had 30psi the other had 15psi.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Exactly what I was thinking , but they can do it with the air pressure the same .
    Its in the manual with any locker bought new , what to expect when throttle input changes abruptly from coast to drive and back again .
  11. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Do you have a locker in the front? Unlock your hubs.
  12. AZPiNsTrIpEd
    Jan 24, 2005
    289
    3/4Tonsville
    No locker in the front, but i do have a detroit in the rear. Didnt even think about checking the tire pressure in the rear, hopefully thats the problem. easy fix:D
