steering pump cooler question
Discussion in 'The Garage' started by Chaddy, Aug 30, 2006.
  1. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I want to run the pump through a cooler and need to no what some of you are running and how you are running it. Pic's would be nice. Thanx in advance.
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Lots of big Fords ran them back in the 70s. The cooler mounted to the pump inself.
  3. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I want to mount 1 somewhere with a fan
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I made a little bracket that I welded off the bottom of the core support, and bent it 45 degrees to the back as to get it out of the way. I dont have pics, but its the lowest spot in the system as to get all the air out.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine is the one on the left. It is a factory tranny cooler. The big one is my new Tranny cooler:D .
    I have replummed it with steel lines it is plumbed after the HB and steering box.
    Ira
  6. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I got mine off a caddy. I've also seen some factory coolers on some new body style Chevy trucks in the junkyard, too.
    I have hydroboost and I just plumbed it in the return line from the steering gear box. It goes from the gear box through the cooler and back to the reservoir.
    I don't know if I was worried about nothing, but I made sure the cooler was lower than the reservoir. I was worried about air getting trapped in the lines.
  7. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I used a tranny cooler my friend didnt need after his manual swap. Plumbed it on the low pressure side and mounted it infront of the radiator behind my grill.
  8. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Thanx Guys:bow: I have a tranny cooler Just sitting around that would be perfect. Also, when you extend the reservoir, How full can you keep it without spilling over?
