steering pump problem maybe not.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 1, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I thought it was my steering pump that has been leaking the steering fluid but I took a closer look at it tonight and it looks like the fluid might be coming from where the steering rod connects to the steering box? Any boidy have any ideas??? hoses look good also
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If the leak is coming from where the steering shaft enters the steering box, you more than likely need to replace the seal...that is what I have to do with mine.
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    how would I go about replacing the seal is the seal your talking about on the outside of the shaft???
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    To be honest, I don't know yet, as I haven't done mine yet. But from what I was told in here is that its on the outside of the steering box and all you have to do is pry the old one off and press the new one in.
