steering pump where do i fill? bleed?
Discussion in 'The Garage' started by muddybuddy, Jan 30, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i jus swapped in my flare style lines from o-ring style, and need to fill the pump back up with fluid, where do i do this? do i need to bleed it also? how do i do that?
    thanks,
    james
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You remove the resevoir cap and fill it from there. As far as bleeding it is recommended that the wheels be off the ground and that you cycle the steering wheel back and forth about 20 times to remove air from the system.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    is there a cap or something i have loosen to remove the air, like with the brakes? or what?
    thanks
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    No, just fill the resevior up to max, jack the front of the truck up. Leave the cap off, the air will escape from here. start the truck and turn the wheel back and forth a few times, lock to lock, check the level again, and continue to turn the wheel back and forth as mentioned around 20 times or so. Make sure fluid is at proper level, cap and go.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    20 times if your lucky!:rolleyes: some steering system are alot more finiky them others. mine took about 200 times (no kidding) to bleed. the proper way is to remove the return line (put it into a bucket and plug the return port at the box) keep the resivoir filled and do it that way. it seems to wrok faster but is more of a pain in the butt.
