Steering question I need some help!
Discussion in 'The Garage' started by patrickcampbell, Sep 14, 2003.
  1. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    Ok one more question, I have a 6" leaf spring lift up fron and a 4" raised steering arm and stock drag ling, Someone gave me a brand new 4" draglink should, now can i put on the draglink with the steering arm or should I go and buy a 2" draglink intead?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't use a bent draglink at all.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I agree. I had a 6" lift with a 4" arm and the 2" draglink and it was actulally too much correction. The straight DL should work just fine. </font>
  4. patrickcampbell
    Sep 11, 2002
    60
    So it would be best to just replace my drag link with a new stock drag link since its about shot, and I shouldnt buy a 2" drop link and make it the even 6" with the lift?
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yes it would be best and no you shouldn't. </font>
  6. patrickcampbell
    Sep 11, 2002
    60
    thanx for the advise shaggy and I have seen your truck on here before, looks good and wheels good to ill bet. /forums/images/graemlins/thumb.gif
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The right way to aproach this is to use a straight draglink and augment the pitman or steering arm to match your lift. A bent draglink does nothing to correct steering geometry, it's only purpose is to bandaid the TieRod Ends so they don't bind against the pitman or steering arm due to the poor geometry.
