steering question(im lifting it higher)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Oct 7, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    im putting an 8in lift on my truck and i know i should conver to Xover but there is a slight problem ($$$$). So for now i was gonna use the existing steering. Should i just use a four inch raise block on the axle(d60) and a four in drop pitman arm? and where can i get a good deal on these things?
    thanks,
    phill
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    never seen a 4" pitman only a 2" at national for $70
    use a dodge d60 arm redrilled for the steering arm. once you get those parts measure what size block you will need.
  3. michaelm
    Feb 2, 2001
    872
    cross over is cheap
    used 2wdr box
    $60 4" dropped arm from parts mike
    $100 arm for the passenger side, ORD isnt the only game in town despite their close ties with this fine site
    stock tie rod ends
    a length of 1.25"x.219"wall tubing for the drag link, will be testing the rumour that the inside dia is perfect for threading within a week
    cant see why anyone would do it the old way now a days
