steering question?
Discussion in 'The Garage' started by 82K5_6.5L, Mar 17, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    ok, when i turn the wheel to the left it makes a full turn like it should..when i turn right, it only goes half way, its maxed out. it sucks /forums/images/graemlins/confused.gif, i cant make good right turns. whats going on here? espicially sucks on the trail trying to make a tight turn. is there something i can do or adjust?
    thanx
  2. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Sounds like you need to adjust the draglink. This will aso affect your steering wheel position. Turn the link till the tires turn the same amount both directions, then adjust a little more to get your wheel straight.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You want the wheel to have more left turn for U turns but it sounds like you have too much. Should be about a 1/2 revolution more to the left than the right
  4. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    cool, sounds good..thanx, i i will have to try that!
