Steering questions
Discussion in 'The Garage' started by airbornesoldier327, Nov 28, 2005.
  1. airbornesoldier327
    airbornesoldier327 1/2 ton status
    Feb 11, 2005
    134
    north carolina
    Alright, heres the problem, i have a skyjacker 6 inch soft ride, but it doesnt have a dropped pitman arm, or the raised steering arm, when i drive down the road i have to turn the wheel like 5-6 inches back and forth to go stait, is that cuased by the lack of the dropped pitman arm, and steering arm? If so which ones do i need to get? thanks for the input guys.
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    check your tierod ends,drag link ends and ball joints.if you havethe cash call ord and do the crossover steering.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    or if u ain't rich, try WFO Concepts or BWP.
    j
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i am installing a cross over next weekend and i'am down the road from ya. you can have my drop pitman when i pull it off (11 dec). it is only a few inch drop but will help you out a bit...
  5. airbornesoldier327
    Feb 11, 2005
    134
    north carolina
    I would really appreciate it, im going to be on block leave around the 2nd of december-3rd of january, but im sure i could fin some one to come pick it up for me. Also do they make a 6inch dropped pitman arm? And what about the steering arm... is that raised or lowered? Thanks guys!
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Are you having lots of play in the steering, or are you having bumpsteer? If it's bumpsteer, it is probably due to the lack of steering correction. Your draglink is supposed to be parallel with the ground, and if you have a stock steering setup, I'll bet that it is angled quite a bit.
    I went with a 4" raised steering arm, that's the best cheap option IMO. I used it with a 6" lift, was great on the highway. A dropped pitman arm puts more leverage on the steering box and frame, I don't really like that idea.
