Steering quirks
Discussion in '1992-Present Chevy & GMC models' started by kyser_soze, Oct 15, 2005.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a 98 k1500 and every once-in-a-while when I am driving down the road the steering wheel just moves while the truck keeps going straight and then returns in the orriginal position.
    Any ideas?
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Are you hitting a bump or pothole while this is happening? Also, Check your steering stabilizer. They do funny things when they go bad.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Yep, I would check all of the steering componets for wear, and take a good look at the idler arm. Also, these trucks have a problem with the speed sensitive steering. When the sensor fails, the steering gets real twitchy cruising down the road.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    the ifs fronts eat ball joints and ideler arms and pitman arms. to check the ball joints need to use floor jack under the lower arm and long bar under tire and pry up to check for play.
    if speed sening steering there will be a sender on the line from the pump near the pump.
