Steering rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 454k30, Jun 15, 2006.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Does anyone know what the part numbers are for the seals on the power steering gearbox? Mine is losing fluid at a rate unacceptable to me. Also if anyone else has done this rebuild do you have any pics or tips on how to accomplish it? Thanks!
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I have an '85 that leaks also (no chit). I looked at the procedure in the factory manual, and convinced myself the leak is not that bad that I can't keep after it with "stop-leak" PS fluid. If it gets serious, I'll replace it with a rebuilt. Looking at the manual, you'll need eye-of-newt, front tooth from a dyke, baby poop straight from the diaper...you get the idea.:haha:
  3. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    reman is much easyer to deal with in my boox.
  4. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    not hard to rebuild, but a pita. But for an extra 10$ you can get a pump with the reservoir vs getting the pump and installing it into your existing reservoir.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I put all new seals in mine 3 times. POS never quit leaking. Reman box - problem cured.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I rebuilt mine when I tapped it for hydro lines. You'll need a dial or lever type torque wrench covering 0 to 20+ in/lb and a very large box wrench for the input lock nut.
    It's not a big job but it is a bit time consuming. If you're not going hydro assist you may well be better off getting a re-man box.
    If you do decide to do it I can give you some photos of what's going on inside with all the ball bearings etc.
