Steering Reservoir, what are you using?
Discussion in 'The Garage' started by yunit, May 5, 2004.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Looking to add one to my setup, but don't want to spend the big doe on an aluminum one. /forums/images/graemlins/thinking.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just do the extended hose thing....that's a cheap way to go
  3. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    This resevoir came out of an older cadi. 3.00 at the local wrecking yard. 5 bucks or so for hose and clamps. I cut the neck off of and old pump and welded a washer with a 5/8 hole in it to the top. Then welded a piece of 5/8 od tubing into the washer to give me a hose mounting point. Then used two hose clamps and a short piece of rad hose to clamp that to my existing pump neck. The low pressure feeds up behind the A/C pump to the cadi res the gravity feeds through the 5/8 hose to the top of the factory pump. It seems to work great.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Mine has a similar setup from an '87 Corvette. But I also have the pump from the 'vette, which doesn't have an integral resevoir. It just has the hose connections. /forums/images/graemlins/thumb.gif
