steering setup
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Apr 21, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    Just installed a 6'' lift on my burb.Everything thing went great except every bolt was seized and removing the steering arm was a Bi@#h!! Had to cut almost all the bolts off.Anyways, the 2 '' adj. drag link.Is there an easy way to set the steering???Both ball joints are right handed threads so you cannot easily adjust like the factory setup.You have to do the whole measuring thing and that isn't working out to well because to adjust the drag link joint must be removed from the steering box measured then reassembled EXACTLY in the right spot.My truck steers right and braking is ridiculous with lots of steering wheel movement.
