Steering shaft removal question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zepplin, Mar 7, 2002.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I already have the steering column out. I am replacing it with a tilt model. Anyway, I still have the steering box bolted on the frame and I have the steering shaft that was connected to the column still connected.
    I noticed there is a bolt and nut with clamp looking thing on the end holding it to the steering box input shaft. I loosened the bolt but I couldn't get the shaft to slide off.
    Is it just rusted on there from old age or would I need a 3 jaw puller of something to separate the two?
    Thanks,
  2. dyeager535
    26,979
    If it's a true clamp (can't remember) you could probably also remove the nut/bolt and spread the clamp enough for easier removal.
    removed other stuff in case the bolt does ride in a groove...
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You have to take the bolt ALL THE WAY OUT. There is a grove in the splined shaft that the bolt rides in.
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    What Triaged said. If it does turn out to be frozen, just take apart the rag joint.
    Pete
  5. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks guys. I only loosened the clamp and pryed on it for a little bit and then gave up. I will take the bolt out this weekend and see how frozen it is.
    Thanks again!
