steering shaft seal?
Discussion in 'The Garage' started by kookydoright, Nov 7, 2005.
  1. kookydoright
    kookydoright Registered Member
    Nov 3, 2005
    16
    oklahoma
    probally a stupid question but, how do you get the steering shaft off so you can get to the ragjoint and the seal?
    80 swb, 50, 700r4,208,10/12blt
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Are you talking about the steering shaft between the gear box and steering column?
    If you are, then loosen and remove the two bots on both ends of the shaft. Gently keep jerking and prying the shaft to collapse the teloscopic portion of the shaft (that is there in the event of a crash, you dont eat your steering wheel). Eventually it will come off. The end by the gear box is splined, and the end on the column is oval(ish).
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    two bolts. they are different sizes. you'll see them on the rag joint. it falls outta the way. then there is a 1/2 inch bolt holding the rag joint on. after i loosened mine i tapped it off with a pickle fork.then the fun begins after the snap ring and the top seal you get to get out the inner seal, not to hard but it takes patience.
