Steering shaft swap, 89 to 79
Discussion in 'The Garage' started by darkshadow, Mar 22, 2007.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    Fixing up my sloppy tilt shaft this weekend, but if it is too far gone i may swap in a non tilt shaft from a 79, but wanted to wire my signal switch in to the older one, so I can have intermitant wipers on the shaft, wireing is not a problem I can make that work, but will the signal from my 89 fit in to a older shaft like that?
  2. dyeager535
    26,982
    191
    No. IIRC the dimmer and wiper are integral on the later housings. That's why your '89 has the large bulge where the lever mounts. (entirely separate piece that sits in there) You need to change the upper half of the column to make it work.
  3. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    OK, is that upper par of the shaft swapable with a non tilt? been a few years since i had a non tilt, i never use it, but this new truck i got offf ebay was loose and in the last week has gotten REALLY bad, flopping around and if it is moved too much the truck dies.
    need to get it fixed befor it falls off!
  4. dyeager535
    26,982
    191
    Good point. I *believe* the upper bowl (plastic housing) is interchangeable tilt/non-tilt, but I can't guarantee it.
    Have you pulled the '89 far enough apart to tighten the bolts that loosen up?
    There is at least one good thread here that tells you how to do it.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Non tilt parts do not interchange with a tilt. I tried it several years ago.
    Even the ignition switch is different between tilt and non tilt.
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    alright thanks, hopfully the barings are not wrecked and tighting the bolts will work
