Steering shaft u-joint Coupling?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by roostr3269, Feb 28, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    Does anyone know of switching couplers from old style u-joint steering to the new style with a 3 inch body lift? thanx for any info.
    live to wheel, wheel to live--1972 gmc jimmy 8 inch lift, 37" ssr's
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    What?
    Are you asking about the steering shaft from the colum to the steering box?
    I have a 3"bodylift and I replace the old rag joint shaft with a Borgsen Ujoint style D-shaft. You can custom cut the Dshaft to fit any length. It was a great improvment for hte 180 bucks it cost me!
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    The AGR steering shaft will work too, it's also cut to fit...I've got it for my 70 Jimmy with a 3" lift. It is a very high quality piece, as is anything from AGR.
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  4. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I welded in a ujoint off a ford escort in place of the rag joint on mine and about three other trucks, no problems yet, and they were given to me. I just made a flat piece to bolt back to box adapter, then welded ujoint to it and to shaft. works great.
    Drive it Like You Hate It!
  5. roostr3269
    Jul 2, 2001
    305
    michigan
    Cool, thanx for the info guys, GM had me wondering if there were any options for me. I will make some calls today, thanx again.
