steering shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Jun 30, 2001.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Got body lift on 2" plus new poly bushings. The stock bushings were much worse than apparent. Most bolts rusted to the point of fragile. Question now is steering shaft. It now appears too short. I am going to jump into it tomorrow, but wanted to know if anyone has had this problem and fixed it without purchasing a new shaft (flamin river more thna likely). I wouldn't mind a new shaft, but want to wait until I have the cash for a rock ram set up. It does look like it slipped some in lengh, but now looks maxed out. I could weld a section in, but wondering if anyone has had bad luck with this. Do really want to have to worry about steering as I am driving. By the way, the more I work on my K5, the more convinced I am tthat if someone says it takes one day, it will take two and LOL, and LOYAC
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. jamiemac
    jamiemac 1/2 ton status
    Mar 26, 2001
    151
    Tennessee
    Here is some pics of some fabs my brother built for our K5's. None of this stuff was ordered. He can custom build any of this stuff for you. He made a really cool steering shaft and deleted the wrag joint. Here's a link to some pics.http://albums.photopoint.com/j/AlbumList?u=1721641
    Sorry try this link:
    <a href=http://albums.photopoint.com/j/AlbumIndex?u=1721641&a=13235753>See my photos of K5 Fabrications at PhotoPoint</a>
    <P ID="edit"><FONT SIZE=-1>Edited by jamiemac on 06/30/01 08:49 PM (server time).</FONT></P>
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    How much would your brother charge for one of those?
    If you didn't build it yourself, how can you call it yours.......?
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I recently had the same problem, after installing the 3" body lift. There are (were) two rivets in my steering shaft. If you drill out the rivets, seperate the two pieces and grind them clean, the shaft will then "slide" within itself and allow for plently of slack to adjust for the difference in your 2" lift.
    Let me know if this works for you! I just had mine done at a local shop because I didn't know this trick at the time! Cost me $30 to learn this one, so get out there and take advantage of my hard-earned $30 - before you drop +$200 on a new shaft!
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  5. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    Yea, that is exactly what I did and then modified a nylon bolt with grinder to go in the hole I drilled out. I am hoping that this will break if ever in a front end collision and steering column is designed to collaspe, if not I'll be eating some steering wheel. No really, I decided to do it as a temporary fix until I get a Rock Ram set-up. I had her out tonight and all worked well.
    The General
  6. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Jamiemac I sent you a private E mail
