Steering shafts
Discussion in 'The Garage' started by crwln73, Mar 18, 2003.
  1. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Has anyone ever used this shaft?
    My problem is I tore a rag joint last weekend at the Hammers.Im thinking of fabin up one similar to this,but without the rag joint.I want to use a small u-joint instead.Like the one that is on the other end.Will this work or do you need a rag joint for a specific reason? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Try Borgeson or Flaming River. Both companies can build the shaft you want. Sorry, I don't have links.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you need a rag joint so you can break it Ken! don't like steering with an abandoned radio antenne?
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I guess Jeeps are good for somethin /forums/images/graemlins/grin.gif
  5. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    /forums/images/graemlins/thumb.gif
    I should of kept that antenne for a souvenir.
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    i have one of those shafts in my rig, borgeson. proven design, works well. the u-joint in the borgeson is really nice, quite a bit nicer than the stock setup. /forums/images/graemlins/smile.gif installation is incredibly simple, even for a novice. I had never taken one off or put one on before and even i knocked it out in no time. /forums/images/graemlins/smile.gif good mod, especially if your stock stuff is getting shady...
    j
  7. Bob Hope
    Bob Hope Registered Member
    Feb 25, 2003
    14
    Pinconning, MI
    the rag joints are usually added for 1 or more of the following
    1. cheaper than a u-joint
    2. noise reduction (pump or gear noise up the column)
    3. ride and handling (so you won't feel every little bump)
    some vehicles don't have the rag joint in the intermediate shaft.
  8. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The new silverados use ujoints at both ends. You might be able to get one and modify it to fit your truck. Or I have also seen them on big trucks.
